Why not use....
Hello Everyone,
Dumb Q....
Since the 46-1201 looks exactly like the 48-1201, why can't any one recapping the 46-1201 use the the schematic for the 48-1201 --it seems to me, to be more detailed. I know i will get flamed for this one....
diyahnih
(remember...I'm a newbie).
Why not use.... - by diyahnih - 07-07-2007, 01:38 AM
[No subject] - by Carl Travis - 07-07-2007, 08:54 AM
46-1201 - by diyahnih - 07-07-2007, 04:43 PM
[No subject] - by Carl Travis - 07-07-2007, 05:58 PM
[No subject] - by Ron Ramirez - 07-07-2007, 06:11 PM
[No subject] - by Carl Travis - 07-08-2007, 08:41 AM
[No subject] - by Ron Ramirez - 07-08-2007, 11:17 AM
[No subject] - by Carl Travis - 07-08-2007, 12:50 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3513 online users. [Complete List]
» 3 Member(s) | 3510 Guest(s)
