Tuning Static Philco 42-PT95
A few questions here.
* With regard to "non residue" "fully evaporating" cleaner, the only isopropyl alchohol spray that I can find (internet search) is a hand pump spray. Is this what you are refering to ? Is there other type/brands [Deoxit ?]. Most tuner/cleaners (as I have found out) contain some type of oil or lubricant which is what got me into this mess in the first place.
* Assuming that I can clean the mica and upper lower plates of the trimmer and the gang, basically what are my steps. [I have been reading and want to be sure that I am on the right track]
- remove the trimmer screws and count number of turns it takes to remove each screw.
- clean mica and upper/lower trimmer plates with fully evaporating cleaner.
- clean gang with fully evaporative cleaner
- reassemble gangs and put screws back in using the same number of turns that it took to remove them
- begin realignment proceedures.
- where exactly are the rotar bearings.
* With regard to realignment. Some questions.
a) Do I adjust the trimmer screws at any time during the realignment [Is this done first, before the adjustment of the IF transformers ?]
b) Is there any article on this Phorum or your site that is a "Realigment 101" ?
It is a learning process. I have dug myself a hole about 10 feet deep, I am trying to claw my way out.
Thanks again for the help.
Tuning Static Philco 42-PT95 - by winkydink - 10-25-2012, 10:11 PM
RE: Tuning Static Philco 42-PT95 - by codefox1 - 10-25-2012, 10:27 PM
RE: Tuning Static Philco 42-PT95 - by winkydink - 10-30-2012, 09:54 AM
RE: Tuning Static Philco 42-PT95 - by winkydink - 10-30-2012, 12:54 PM
RE: Tuning Static Philco 42-PT95 - by winkydink - 10-30-2012, 01:11 PM
RE: Tuning Static Philco 42-PT95 - by winkydink - 10-30-2012, 04:38 PM
RE: Tuning Static Philco 42-PT95 - by winkydink - 10-30-2012, 09:35 PM
RE: Tuning Static Philco 42-PT95 - by winkydink - 10-31-2012, 08:56 AM
RE: Tuning Static Philco 42-PT95 - by winkydink - 10-31-2012, 09:21 AM
RE: Tuning Static Philco 42-PT95 - by winkydink - 11-08-2012, 02:19 PM
RE: Tuning Static Philco 42-PT95 - by codefox1 - 11-08-2012, 02:36 PM
RE: Tuning Static Philco 42-PT95 - by winkydink - 11-08-2012, 02:45 PM
RE: Tuning Static Philco 42-PT95 - by codefox1 - 11-08-2012, 07:00 PM
RE: Tuning Static Philco 42-PT95 - by morzh - 11-10-2012, 07:28 PM
RE: Tuning Static Philco 42-PT95 - by winkydink - 11-12-2012, 10:28 AM
