Why not use....
You really should use the service info for the 46-1201 to service the 46-1201, and the 48-1201 schematic to service the 48-1201. As has been previously mentioned, there are differences between the two.
The PDF package I have available here at the Phorum (at http://www.philcoradio.com/phorum/showth...hp?tid=215) gives not only the basic service info for Model 46-1201, but also all of the factory updates and changes. This should get you through any 46-1201 service problem. And the price is right (FREE).
Why not use.... - by diyahnih - 07-07-2007, 01:38 AM
[No subject] - by Carl Travis - 07-07-2007, 08:54 AM
46-1201 - by diyahnih - 07-07-2007, 04:43 PM
[No subject] - by Carl Travis - 07-07-2007, 05:58 PM
[No subject] - by Ron Ramirez - 07-07-2007, 06:11 PM
[No subject] - by Carl Travis - 07-08-2007, 08:41 AM
[No subject] - by Ron Ramirez - 07-08-2007, 11:17 AM
[No subject] - by Carl Travis - 07-08-2007, 12:50 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
There are currently 3483 online users. [Complete List]
» 2 Member(s) | 3481 Guest(s)
