Philco Logo
I was working with a mail order screen shop to apply the Philco Logo on a small towel to place on my Radio Top. They declined to reproduce because of potential Patent Infringement concerns. Anyone have similar experience? I sent them the JPG found on the internet?
Philco Logo - by Radioguy52 - 11-01-2012, 08:44 PM
RE: Philco Logo - by jerryhawthorne - 11-03-2012, 05:06 PM
RE: Philco Logo - by Radioguy52 - 11-08-2012, 11:12 PM
Philco 91 Tuning Condenser
