Zenith 9-S-262 Alignment Questions
I don't remember problems with step 3.
BTW do you use insulated tool to turn the trimmer?
And, the tuning eye still is not the best way. If you have a meter, it will benefit you to use it. I mean, if you are into the old radios, you gotta have some sort of a meter, DMM or such.
Zenith 9-S-262 Alignment Questions - by Geoff - 10-24-2012, 03:36 PM
RE: Zenith 9-S-262 Alignment Questions - by Geoff - 10-24-2012, 06:16 PM
RE: Zenith 9-S-262 Alignment Questions - by Geoff - 10-24-2012, 08:27 PM
RE: Zenith 9-S-262 Alignment Questions - by Geoff - 10-24-2012, 10:28 PM
RE: Zenith 9-S-262 Alignment Questions - by Geoff - 10-25-2012, 12:20 PM
RE: Zenith 9-S-262 Alignment Questions - by morzh - 10-25-2012, 08:33 PM
RE: Zenith 9-S-262 Alignment Questions - by Geoff - 10-25-2012, 11:31 PM
RE: Zenith 9-S-262 Alignment Questions - by Geoff - 11-02-2012, 11:51 AM
RE: Zenith 9-S-262 Alignment Questions - by morzh - 11-02-2012, 06:37 PM
RE: Zenith 9-S-262 Alignment Questions - by Geoff - 11-02-2012, 07:00 PM
