Philco (UK) Model 282 Empire Five
Arran, yes, the front corners do appear to be solid walnut. It looks better than the cheap "white wood" typically used by USA Philco in those areas of a cabinet.
Bill (exray) - I just finished examining the front panel closely, and no, it is not photofinish - it is the real deal, actual veneer work. I can't think of any USA Philco tombstone that has this much fancy veneer work on its front panel.
The top of the set has been refinished at some point; I found several runs in the finish at the upper left edge.
RE: Philco (UK) Model 282 Empire Five - by Arran - 11-02-2012, 08:19 PM
RE: Philco (UK) Model 282 Empire Five - by exray - 11-03-2012, 06:27 AM
RE: Philco (UK) Model 282 Empire Five - by Ron Ramirez - 11-03-2012, 08:03 AM
RE: Philco (UK) Model 282 Empire Five - by Arran - 11-06-2012, 02:08 AM
RE: Philco (UK) Model 282 Empire Five - by Arran - 11-08-2012, 12:46 AM
RE: Philco (UK) Model 282 Empire Five - by Jamie - 08-08-2013, 08:11 AM
RE: Philco (UK) Model 282 Empire Five - by GarySP - 08-08-2013, 10:53 AM
RE: Philco (UK) Model 282 Empire Five - by Arran - 09-18-2013, 10:26 PM
RE: Philco (UK) Model 282 Empire Five - by Arran - 11-19-2018, 05:23 AM
There are currently 5241 online users. [Complete List]
» 5 Member(s) | 5236 Guest(s)
AvatarAvatarAvatarAvatar
