Redoing / Touching up Trim 42-PT95
Make certain you get to GoJo that does not have pumice in it. That stuff is too abrasive. Also Deft Lacquer was relabeled some time ago as a Brushing Lacquer. Indeed, some people do quite well applying with a brush, I was never that good at it. I have heard that the relabel was due to emissions from spraying. It works quite nicely with reduced with lacquer thinner and shot from a spray gun. I don't recall if Deft packages their lacquer in rattle cans any longer.
Jerry
Redoing / Touching up Trim 42-PT95 - by winkydink - 11-03-2012, 08:15 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-05-2012, 01:59 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-07-2012, 12:23 AM
RE: Redoing / Touching up Trim 42-PT95 - by jerryhawthorne - 11-07-2012, 02:43 PM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-08-2012, 02:05 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-09-2012, 12:45 AM
New member
Philco 630csx power cord
New member
There are currently 2965 online users. [Complete List]
» 6 Member(s) | 2959 Guest(s)
AvatarAvatarAvatarAvatar
