Redoing / Touching up Trim 42-PT95
A Couple of Questions and Comments
#1) Ron you stated
Quote:For the body of the cabinet, you probably won't need to prime if you spray the entire cabinet with Mohawk Medium Walnut first to get the cabinet the proper color
*** This Mohawk Medium Walnut is this a spray lacquer or a stain or a finish toner ?????? Can you provide a link ????? *****
I can find Mohawk Tone Finisher, and Ultra Classic Toner in Medium Brown Walnut, but not a tinted lacquer.
http://woodfinisherssource.com/cart/aero...100-0207/
http://woodfinisherssource.com/cart/aero...m101-0207/
#2) I can find Deft in spray cans online (but not locally, my Lowes & Home Depot do not have them in stock). Which should I use: Gloss, Satin or Sanding Sealer ? ? ?
Would Valspar Clear Gloss Spray Lacquer be an acceptable substitute ?
http://www.lowes.com/pd_282334-4-410.006...facetInfo=
#3) If I go the stripping route for the finish, what can I do about the Philco decal in the front ? Are new ones available ? Do I mask that off and try to "blend" the finish around the decal area ???
#4) Cleaning cabinet with Gojo. I have read that you use #0000 Steel wool and the gojo ? How do you clean the gojo off the cabinet, just wipe it off after it has been rubbed in ?
Thanks again for all your assistance !
Redoing / Touching up Trim 42-PT95 - by winkydink - 11-03-2012, 08:15 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-05-2012, 01:59 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-07-2012, 12:23 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-08-2012, 02:05 AM
RE: Redoing / Touching up Trim 42-PT95 - by winkydink - 11-08-2012, 08:50 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-09-2012, 12:45 AM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4017 online users. [Complete List]
» 1 Member(s) | 4016 Guest(s)
