need info (schematic)
Ok thanks Ron for such a quick reply. Um, i dont have a site right now, but i could email a photo or two , rickd. My mail is under my profile, send me yours.
need info (schematic) - by Guest - 07-08-2007, 01:29 AM
[No subject] - by rickd - 07-08-2007, 08:51 AM
[No subject] - by Guest - 07-08-2007, 03:14 PM
[No subject] - by rickd - 07-08-2007, 10:46 PM
[No subject] - by Guest - 07-08-2007, 11:06 PM
[No subject] - by Guest - 07-08-2007, 11:18 PM
[No subject] - by Ron Ramirez - 07-08-2007, 11:53 PM
[No subject] - by Guest - 07-09-2007, 01:25 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
There are currently 3471 online users. [Complete List]
» 2 Member(s) | 3469 Guest(s)
