Which Tenite Parts Do You Most Need?
My vote is for the 1941-42 Philco models using the same type grille, the most popular of which is the 41-226 "Sled" but also includes the following:
41-84T
41-85T
41-221C
41-221CI (ivory grille)
41-841T
41-842T
41-843T
41-844T
41-851T
42-842T
42-843T
42-844T
42-853T
42-854T
42-PT94
42-PT95 (ivory)
47-204 (ivory, not Tenite as no examples I have seen have shrunk)
These, I believe, are what you are referring to as the Philcos "with rectangular heating register type grilles."
Are you working on possible replacements for what you have listed, or merely compiling a list? Just curious...
RE: Which Tenite Parts Do You Most Need? - by Ron Ramirez - 11-08-2012, 09:34 PM
There are currently 11431 online users. [Complete List]
» 2 Member(s) | 11429 Guest(s)
