Proper toners for Philco 16B cathedral
Hi everyone,
I need to refinish a Philco 16B cathedral cabinet. I just need advice on the proper toners (Mohawk?) for this cabinet. What have you used that has worked well?
Proper toners for Philco 16B cathedral - by don'tdomelikethat - 07-09-2007, 08:39 AM
[No subject] - by Ron Ramirez - 07-09-2007, 05:55 PM
There are currently 9555 online users. [Complete List]
» 3 Member(s) | 9552 Guest(s)
