Philco (UK) Model 282 Empire Five
About the eight jack terminal board...one is for the antenna, one for ground or "Earth" as it's called over there...one "Red" and one "Black" for the Philco All-Wave Aerial...two are for an external speaker...and two for "gramophone" (phonograph) input.
By the way, I moved your other post into a new thread of its own:
http://www.philcoradio.com/phorum/showth...p?tid=5444
RE: Philco (UK) Model 282 Empire Five - by Arran - 11-02-2012, 08:19 PM
RE: Philco (UK) Model 282 Empire Five - by exray - 11-03-2012, 06:27 AM
RE: Philco (UK) Model 282 Empire Five - by Arran - 11-06-2012, 02:08 AM
RE: Philco (UK) Model 282 Empire Five - by Arran - 11-08-2012, 12:46 AM
RE: Philco (UK) Model 282 Empire Five - by Ron Ramirez - 11-09-2012, 07:45 PM
RE: Philco (UK) Model 282 Empire Five - by Jamie - 08-08-2013, 08:11 AM
RE: Philco (UK) Model 282 Empire Five - by GarySP - 08-08-2013, 10:53 AM
RE: Philco (UK) Model 282 Empire Five - by Arran - 09-18-2013, 10:26 PM
RE: Philco (UK) Model 282 Empire Five - by Arran - 11-19-2018, 05:23 AM
Users browsing this thread: 14 Guest(s)
There are currently 7037 online users. [Complete List]
» 3 Member(s) | 7034 Guest(s)
