Reasonable Offer for 16b Peaked Tombstone
There is an EvilPay listing for the above mentioned radio. It is fairly local to me, less than 1 hr, and the seller is willing to offer local pick up.
http://www.ebay.com/itm/BEAUTIFUL-VINTAG...5aead48a95
The BIN price is quite high @ $375, and I would like to make an offer and I was hoping for some guidance. I have the cathedral that I only paid $100 for, but I think that was just luck on my part. What says the Phorum brain trust, what's a realistic offer for this? I am attempting to collect all the 16b and 116 table models. Of them all, this one is my favorite cabinet.
Philco 91 Tuning Condenser
