Philco 19 cabinet
The ones I have seen that were in very good shape appear to have the equivalent of Medium Walnut on the body of the cabinet, with just enough Extra Dark Walnut on the front panel to give a two-tone contrast without going overboard. This seems to be true of all 1932-34 Philcos of that particular style, with the inset front panel.
Philco 19 cabinet - by old_radios - 07-05-2007, 12:20 PM
[No subject] - by Ron Ramirez - 07-09-2007, 05:58 PM
There are currently 6269 online users. [Complete List]
» 4 Member(s) | 6265 Guest(s)
AvatarAvatarAvatarAvatar
