38-10 Finished
Excellent job on the chassis! I am currently doing a resto on a model 15X chassis and am also going for the natural metal finish look. It's a lot of work!!!!!
38-10 Finished - by FStephenMasek - 03-20-2011, 02:54 PM
RE: 38-10 Finished - by FStephenMasek - 11-08-2012, 08:00 PM
RE: 38-10 Finished - by Eric T - 11-10-2012, 12:13 PM
RE: 38-10 Finished - by codefox1 - 11-10-2012, 01:56 PM
RE: 38-10 Finished - by TA Forbes - 11-10-2012, 09:27 PM
RE: 38-10 Finished - by chris25260880 - 11-11-2012, 12:21 AM
RE: 38-10 Finished - by Todd - 02-24-2013, 08:08 PM
RE: 38-10 Finished - by Tom Hamilton - 03-04-2013, 11:40 AM
Re: 38-10 finsihed - by Michael Dennis - 03-20-2011, 02:57 PM
Re: 38-10 finsihed - by 7estatdef - 03-22-2011, 04:32 PM
Re: 38-10 Finished - by FStephenMasek - 03-22-2011, 06:24 PM
Re: 38-10 Finished - by Ron Ramirez - 03-22-2011, 07:21 PM
Re: 38-10 Finished - by FrAnKiViTy - 03-22-2011, 08:21 PM
Re: 38-10 Finished - by FStephenMasek - 03-22-2011, 08:22 PM
Re: 38-10 Finished - by Chuck Schwark - 03-23-2011, 09:29 AM
Re: 38-10 Finished - by FStephenMasek - 03-23-2011, 10:16 PM
Philco 91 Tuning Condenser
There are currently 6641 online users. [Complete List]
» 1 Member(s) | 6640 Guest(s)
