Which Tenite Parts Do You Most Need?
The escutchion on the 1942 Philcos like that found on the 42-122T, 42-125K and 42-124T are usually warped badly.
Personally, I would love to find the escutchion and knobs for a Midwest 181 that were not warped. I have two sets now, one set is pretty bad and the one I intend to use on my set (assuming that I FINISH it) is just warped.
RE: Which Tenite Parts Do You Most Need? - by TA Forbes - 11-10-2012, 11:33 PM
There are currently 10540 online users. [Complete List]
» 2 Member(s) | 10538 Guest(s)
