Reasonable Offer for 16b Peaked Tombstone
WOW!! Very nice condition! Your 16 is an earlier (1934) model. The only (minor) headache restoring it will be re-stuffing the electrolytic can. Sometimes the contents come right out, sometimes they don't.
There are several threads here in the Phorum that outline how to do the cans.
Philco 91 Tuning Condenser
