I recently acquired a 640X that belonged to my dad. It had been stored in a damp storage shed which damaged the cabinet. I am not sure if the sides, top and front of the cabinet are black or ebony. Is the finish supposed to be a high gloss or satin? Any help would be greatly appreciated.
Allen
640X - by Guest - 07-14-2007, 04:55 PM
[No subject] - by Ron Ramirez - 07-14-2007, 06:39 PM
Philco 91 Tuning Condenser
