Philco Console Model 38-8
Tell us approximately where you live. Sadly, the cost of shipping often exceeds any reasonable value of these old sets. I'm not personally interested.
If all else fails, drop a dime or two to see if any of the local High School Shop teachers or local hobbiest groups might want it.
Philco Console Model 38-8 - by NovicePhilco - 11-15-2012, 11:04 AM
RE: Philco Console Model 38-8 - by codefox1 - 11-15-2012, 03:59 PM
RE: Philco Console Model 38-8 - by Ron Ramirez - 11-15-2012, 04:45 PM
RE: Philco Console Model 38-8 - by codefox1 - 11-15-2012, 05:50 PM
RE: Philco Console Model 38-8 - by NovicePhilco - 11-16-2012, 11:36 AM
Philco 91 Tuning Condenser
There are currently 5354 online users. [Complete List]
» 1 Member(s) | 5353 Guest(s)
