  • 1 Vote(s) - 5 Average
Zenith 9-S-262 Restoration Chronicles
#40
Thanks for the tip! Yeh, from the rear you need to remove the chassis pulling it straight back, then lifting it up a bit, and then tilt the end of the chassis that has the tone control down as you pull the chassis out. Otherwise you will hit the tone control on the support on the back of the cabinet.
- Geoff
Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:56 AM
RE: Zenith 9-S-262 Restoration Chronicles - by Geoff - 11-15-2012, 07:36 PM
There are currently 3474 online users. [Complete List]
» 1 Member(s) | 3473 Guest(s)
