philco 42-1012
Has not played as it should since I first received this replacement chassis.
Condition unknown when I got it.
Owner said the tranny was good.
After I received it I re-capped it and replaced the tubes.
Re-checked tubes, except the xxl tube,which is not in my tube tester book.
Some of the resistors are a bear to get at and have short leads,which makes them hard to check.
Do you check them in place, or snip one end and test for a more accurate reading?
The volume switch was replaced some years back as well.
Could be a problem there?
The pushbutton power button went bad,so they replaced the power switch with a volume/power switch instead.
murf
philco 42-1012 - by murf - 11-14-2012, 11:06 AM
RE: philco 42-1012 - by codefox1 - 11-14-2012, 11:45 AM
RE: philco 42-1012 - by morzh - 11-16-2012, 12:36 AM
RE: philco 42-1012 - by murf - 11-16-2012, 07:56 AM
RE: philco 42-1012 - by morzh - 11-16-2012, 04:16 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
