Thanks Ron for your "Notes on Model 116"
Thanks Ron, I've just run into one of these beasts. It's a 116B I picked up at the last Estes auction. It has the changes you describe (http://philcoradio.com/phorum/showthread.php?tid=14957)with one additional twist. It has the unusual resistor leading from the volume control like the earlier version. What would the purpose of this resistor be? This is going to be a very nice radio.
Steve Chambers
Warren, Ohio[/url]
Thanks Ron for your "Notes on Model 116" - by Steve Chambers - 07-19-2007, 08:07 PM
[No subject] - by Ron Ramirez - 07-22-2007, 09:31 AM
The speaker table error?
Philco 70 antenna lead
