New Philcos
I have have also heard that these sets use a multitude of 6J5 tubes, I remember someone accusing Philco of tube stuffing the set because of that. I suppose they could have accomplished the same result with 8 or 9 tubes by designing the circuit differently, or by using twin triodes, but for some reason Philco went the other way.
New Philcos - by Gene Pederson - 11-15-2012, 06:21 PM
RE: New Philcos - by Arran - 11-15-2012, 11:10 PM
RE: New Philcos - by chris25260880 - 11-16-2012, 02:10 AM
RE: New Philcos - by TA Forbes - 11-16-2012, 03:17 PM
RE: New Philcos - by Arran - 11-16-2012, 11:35 PM
RE: New Philcos - by Ron Ramirez - 11-17-2012, 07:15 AM
RE: New Philcos - by TA Forbes - 11-19-2012, 02:34 PM
RE: New Philcos - by TA Forbes - 11-19-2012, 02:36 PM
RE: New Philcos - by Gene Pederson - 12-12-2012, 10:36 PM
RE: New Philcos - by TA Forbes - 12-13-2012, 01:14 PM
Philco 91 Tuning Condenser
