  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
Well the moment of truth came this afternoon. I set everything up on the test bench and turned the variac knob. Unfortunately all I got was silence then a little bit of hum. I know all the tubes are good and the transformers have no open windings. I want to check voltages but can't find a voltage table in my papers anywhere. If anyone has one please let me know.
RE: Growing up quick...with a 38-690xx Pics added. - by badwaxcaps - 11-17-2012, 01:17 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
