Philco 70 Cabinet
Thanks Jerry. It's on display right above the 111. It would look better if it had a chassis in it.
Philco 70 Cabinet - by Phlogiston - 11-17-2012, 06:40 PM
RE: Philco 70 Cabinet - by Gene Pederson - 11-17-2012, 06:59 PM
RE: Philco 70 Cabinet - by Phlogiston - 11-17-2012, 07:19 PM
RE: Philco 70 Cabinet - by jerryhawthorne - 11-17-2012, 10:35 PM
RE: Philco 70 Cabinet - by Phlogiston - 11-17-2012, 10:49 PM
RE: Philco 70 Cabinet - by 7estatdef - 11-18-2012, 09:52 AM
RE: Philco 70 Cabinet - by Steve Davis - 11-18-2012, 01:37 PM
RE: Philco 70 Cabinet - by Steve Davis - 11-18-2012, 02:01 PM
RE: Philco 70 Cabinet - by LedHed - 11-18-2012, 06:08 PM
RE: Philco 70 Cabinet - by TA Forbes - 11-19-2012, 02:05 PM
RE: Philco 70 Cabinet - by Phlogiston - 11-19-2012, 04:36 PM
RE: Philco 70 Cabinet - by Art Hoch - 11-19-2012, 06:56 PM
RE: Philco 70 Cabinet - by jerryhawthorne - 11-27-2012, 07:31 PM
RE: Philco 70 Cabinet - by Steve Davis - 11-27-2012, 08:38 PM
RE: Philco 70 Cabinet - by Phlogiston - 11-27-2012, 09:06 PM
RE: Philco 70 Cabinet - by autoradiotech - 11-27-2012, 10:38 PM
RE: Philco 70 Cabinet - by Phlogiston - 11-28-2012, 02:20 AM
RE: Philco 70 Cabinet - by Ron Ramirez - 11-28-2012, 06:41 AM
RE: Philco 70 Cabinet - by Geoff - 11-28-2012, 03:47 PM
RE: Philco 70 Cabinet - by Phlogiston - 12-05-2012, 01:14 AM
Philco 91 Tuning Condenser
