  • 1 Vote(s) - 5 Average
Another 90 Question concerning grommets last post.
Just adding another question now that the Philco 90 is running pretty well. A few things to sort but getting there. My question is what would you suggest for the grommets (3) that attach the tuning caps to the chassis? I get a little confused searching through various web sites. The tuner just rocks back and forth and the grommets are crispy critters. Thanks for any advise.
Jerry
Philco 91 Tuning Condenser
