Philco QC?
I'm sure those are contruction station marks, q/c and re-work markings, as well as final "ok". Since Philco used several outside cabinet shops, besides their in-house, cabinet marks will vary from jobbers. I know that the cabinet shop "number" was uaually in the cabinets too.
Ron has a listing of them here on his site.
I'm sure Ron and elucidate and or correct me. He is the Philco cabinet guru.
Chuck
Philco QC? - by jerryhawthorne - 11-18-2012, 08:30 PM
RE: Philco QC? - by Chuck Schwark - 11-19-2012, 09:49 AM
RE: Philco QC? - by jerryhawthorne - 11-19-2012, 12:45 PM
RE: Philco QC? - by Chuck Schwark - 11-19-2012, 01:25 PM
RE: Philco QC? - by codefox1 - 11-19-2012, 01:32 PM
Philco 91 Tuning Condenser
There are currently 5334 online users. [Complete List]
» 1 Member(s) | 5333 Guest(s)
