Philco QC?
Thanks Chuck. The markings I'm referring to are on the metal chassis. On one set they go around the outside, the other set in marked around the inside of the chassis.
Jerry
Philco QC? - by jerryhawthorne - 11-18-2012, 08:30 PM
RE: Philco QC? - by Chuck Schwark - 11-19-2012, 09:49 AM
RE: Philco QC? - by jerryhawthorne - 11-19-2012, 12:45 PM
RE: Philco QC? - by Chuck Schwark - 11-19-2012, 01:25 PM
RE: Philco QC? - by codefox1 - 11-19-2012, 01:32 PM
Philco 91 Tuning Condenser
There are currently 5374 online users. [Complete List]
» 1 Member(s) | 5373 Guest(s)
