Not sure what i have...HELP??
Hi Deb and Welcome to the Phourm!!!
Without a pic it going to be tough! You maybe able to find a small blue and white sticker on the inside of the cabinet that will display the model number. It may also be stamped in ink on the chassis. Most of the time it will be two digits a dash and one-three more digits. The first two will be the year it was made. Did you have a look in the Gallery??
Not sure what i have...HELP?? - by cddckd - 11-19-2012, 03:44 PM
RE: Not sure what i have...HELP?? - by 7estatdef - 11-19-2012, 04:08 PM
RE: Not sure what i have...HELP?? - by cddckd - 11-19-2012, 04:37 PM
RE: Not sure what i have...HELP?? - by 7estatdef - 11-19-2012, 07:57 PM
RE: Not sure what i have...HELP?? - by TA Forbes - 11-21-2012, 11:42 AM
RE: Not sure what i have...HELP?? - by 7estatdef - 11-21-2012, 09:47 PM
RE: Not sure what i have...HELP?? - by TA Forbes - 11-21-2012, 10:17 PM
Philco 91 Tuning Condenser
