New Set
I've had it for about 25yrs now and it just sucks up all of your energy along with joint pain. I just got back from a week cruse to the Bahamas I'm still working full time and it was GREAT!!! Was feeling better after a day or twohttp://www.philcoradio.com/phorum/images/smilies/icon_biggrin.gif. As soon as I got back home (Saturday) the aches and pain came backhttp://www.philcoradio.com/phorum/images/smilies/icon_sad.gif
NOTHING like having breakfast at 11am for days in a row coming back to your room and taking a NAP!!!!
ps. Tnx much for your well wishes guys!!!
New Set - by 7estatdef - 11-19-2012, 02:05 PM
RE: New Set - by 7estatdef - 11-19-2012, 02:25 PM
RE: New Set - by TA Forbes - 11-19-2012, 02:39 PM
RE: New Set - by Ron Ramirez - 11-19-2012, 03:04 PM
RE: New Set - by TA Forbes - 11-19-2012, 03:12 PM
RE: New Set (off topic) - by 7estatdef - 11-19-2012, 04:19 PM
Philco 91 Tuning Condenser
