  • 1 Vote(s) - 2 Average
First Philco Restoration Finished
Thank you all. Steve D, this is how the condition of the dial was when I bought it, I did not do anything to clean it up except to brush off the dust.
Jon
RE: First Philco Restoration Finished - by Philco281989 - 11-21-2012, 11:50 AM
Philco 91 Tuning Condenser
