Philco Model 66 Repair
Use your soldering iron on the shaft of seized control. Apply heat down near where the shaft enter the pot. Use plenty of something like wd-40 on the shaft. This will eventually work the shaft free. Don't try to force it. Learned the hard way on this. Just finished two 66's- real nice sounding radios.
Good luck.
Philco Model 66 Repair - by radiola - 11-21-2012, 12:43 AM
RE: Philco Model 66 Repair - by 7estatdef - 11-21-2012, 06:07 PM
RE: Philco Model 66 Repair - by jph14 - 11-21-2012, 07:53 PM
RE: Philco Model 66 Repair - by radiola - 11-21-2012, 08:00 PM
RE: Philco Model 66 Repair - by 7estatdef - 11-21-2012, 10:08 PM
RE: Philco Model 66 Repair - by TA Forbes - 11-21-2012, 10:25 PM
RE: Philco Model 66 Repair - by radiola - 11-21-2012, 11:10 PM
RE: Philco Model 66 Repair - by 7estatdef - 11-22-2012, 12:58 AM
RE: Philco Model 66 Repair - by radiola - 11-23-2012, 10:12 PM
RE: Philco Model 66 Repair - by 7estatdef - 11-25-2012, 05:39 PM
RE: Philco Model 66 Repair - by radiola - 11-25-2012, 06:20 PM
RE: Philco Model 66 Repair - by jerryhawthorne - 11-25-2012, 09:30 PM
RE: Philco Model 66 Repair - by radiola - 11-25-2012, 10:48 PM
RE: Philco Model 66 Repair - by 7estatdef - 11-25-2012, 11:21 PM
RE: Philco Model 66 Repair - by radiola - 11-26-2012, 10:01 PM
RE: Philco Model 66 Repair - by 7estatdef - 11-27-2012, 12:16 AM
RE: Philco Model 66 Repair - by radiola - 11-27-2012, 01:12 AM
RE: Philco Model 66 Repair - by 7estatdef - 11-27-2012, 11:20 PM
RE: Philco Model 66 Repair - by TA Forbes - 11-27-2012, 11:47 PM
RE: Philco Model 66 Repair - by radiola - 11-28-2012, 12:34 AM
RE: Philco Model 66 Repair - by 7estatdef - 11-28-2012, 11:32 PM
RE: Philco Model 66 Repair - by radiola - 11-29-2012, 02:21 AM
RE: Philco Model 66 Repair - by 7estatdef - 11-29-2012, 10:30 PM
RE: Philco Model 66 Repair - by radiola - 11-30-2012, 02:32 AM
RE: Philco Model 66 Repair - by 7estatdef - 11-30-2012, 06:54 PM
RE: Philco Model 66 Repair - by radiola - 11-30-2012, 11:30 PM
RE: Philco Model 66 Repair - by 7estatdef - 12-01-2012, 06:51 PM
RE: Philco Model 66 Repair - by radiola - 12-02-2012, 10:41 PM
RE: Philco Model 66 Repair - by 7estatdef - 12-02-2012, 10:53 PM
RE: Philco Model 66 Repair - by 7estatdef - 12-04-2012, 11:00 PM
RE: Philco Model 66 Repair - by radiola - 12-05-2012, 12:52 AM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
There are currently 4010 online users. [Complete List]
» 2 Member(s) | 4008 Guest(s)
