I am looking for a Zenith...maybe....with the tuning eye
I dunno about a Zenith with those qualifications.. Other than the Walton sets I can only find a couple of that brand tabletop with the tuning eye. A 9S324, a 10S443 (Ugly 1940 set) and a 7S323 (same cabinet as the 9S324.)
I'm far from an expert, but have you considered a nice RCA? Lots of tuning eye models to choose from and you don't have to pay the "Brand Z Tax" tm.
RE: I am looking for a Zenith...maybe....with the tuning eye - by LedHed - 11-21-2012, 09:51 PM
There are currently 10407 online users. [Complete List]
» 2 Member(s) | 10405 Guest(s)
