I am looking for a Zenith...maybe....with the tuning eye
Where are you located at? I found mine on craigslist (RCA 9T) and my consoles through am auction. I recall seeing a 6T on craigslist recently... Anyone else have any thoughts?
One cannot forbid people to be idiots....all one can do is try not to be one. -Morzh
RE: I am looking for a Zenith...maybe....with the tuning eye - by LedHed - 11-21-2012, 11:45 PM
