A Philco 118 Chassis
I have no idea why I decided I wanted this, but here it is. Maybe I am going to find a 118B cabinet and speaker????
[Image: http://i1185.photobucket.com/albums/z345...philco.jpg]
Gene
A Philco 118 Chassis - by Gene Pederson - 11-23-2012, 08:53 PM
RE: A Philco 118 Chassis - by 7estatdef - 11-23-2012, 09:16 PM
RE: A Philco 118 Chassis - by TA Forbes - 11-23-2012, 10:12 PM
RE: A Philco 118 Chassis - by Gene Pederson - 11-24-2012, 09:15 PM
RE: A Philco 118 Chassis - by TA Forbes - 11-24-2012, 09:58 PM
Philco 91 Tuning Condenser
