Philco model 39-5505
A little while back someone on CL posted a Philco console for sale as a model 39-5505. Although they said they weren't sure that was the model.
Gene
Philco model 39-5505 - by Eric Adams - 11-23-2012, 11:51 AM
RE: Philco model 39-5505 - by 7estatdef - 11-23-2012, 11:57 AM
RE: Philco model 39-5505 - by Ron Ramirez - 11-23-2012, 03:36 PM
RE: Philco model 39-5505 - by Eric Adams - 11-23-2012, 11:53 PM
RE: Philco model 39-5505 - by Ron Ramirez - 11-24-2012, 12:09 AM
RE: Philco model 39-5505 - by Eric Adams - 11-24-2012, 10:52 AM
RE: Philco model 39-5505 - by Ron Ramirez - 11-25-2012, 12:01 AM
RE: Philco model 39-5505 - by Eric Adams - 11-25-2012, 12:20 AM
RE: Philco model 39-5505 - by Ron Ramirez - 11-25-2012, 09:34 AM
RE: Philco model 39-5505 - by TA Forbes - 11-25-2012, 11:13 AM
RE: Philco model 39-5505 - by Eric Adams - 11-25-2012, 11:33 AM
RE: Philco model 39-5505 - by Ron Ramirez - 11-25-2012, 12:06 PM
RE: Philco model 39-5505 - by Gene Pederson - 11-25-2012, 05:48 PM
RE: Philco model 39-5505 - by 7estatdef - 11-25-2012, 11:27 PM
Philco 91 Tuning Condenser
