  • 1 Vote(s) - 5 Average
Another 90 Question concerning grommets last post.
Jerryhwthorne I ordered the Philco 90 tuner grommets from Radiodaze. But I think I installed them upside down because when I installed the chassis in the cabinet the tuning dial sits a little too low. I installed them from the bottom with the thicker side down inside the chassis. I had a 50/50 shot and naturally got it wrong. When I start work on it again I'll reverse them and it should be ok. Mine were petrified and I don't think even CSI could have determined what they originally looked like.
Philco 91 Tuning Condenser
There are currently 5304 online users. [Complete List]
» 1 Member(s) | 5303 Guest(s)
