Redoing / Touching up Trim 42-PT95
I will post pictures of the "finished" product soon. It looks nice and much, much better than when I started. I know that I cut some corners not using the tinted lacquer and for my next refinish, I plan to do so, once I can find a dealer that is less expensive than the ones I have found. I just need to find the time to do the research.
Question: I have purchased a replacement decal for another 42-PT95 that was missing the "PHILCO Transitone" label on the front of the radio. I purchased this from Radio Daze. How do I go about applying it ? Is it a "water" decal ?
I was hoping that there were instructions from Radio Daze, but alas, none were in the envelope.
Redoing / Touching up Trim 42-PT95 - by winkydink - 11-03-2012, 08:15 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-05-2012, 01:59 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-07-2012, 12:23 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-08-2012, 02:05 AM
RE: Redoing / Touching up Trim 42-PT95 - by Arran - 11-09-2012, 12:45 AM
RE: Redoing / Touching up Trim 42-PT95 - by winkydink - 11-27-2012, 11:57 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2418 online users. [Complete List]
» 1 Member(s) | 2417 Guest(s)
