My first Zenith
Most of the ones I've serviced have had the large chassis consoles. Those the caps are like a bb in a boxcar, lots of room. Do have a 1940 table set that crammed + rubber wire!!! Pitb to service.
My first Zenith - by Groundhog74 - 11-27-2012, 08:15 AM
RE: My first Zenith - by TA Forbes - 11-27-2012, 03:11 PM
RE: My first Zenith - by 7estatdef - 11-27-2012, 11:30 PM
RE: My first Zenith - by TA Forbes - 11-27-2012, 11:54 PM
There are currently 10434 online users. [Complete List]
» 1 Member(s) | 10433 Guest(s)
