Can anyone identify this radio
+++ for you Ron, you do style flex! I guess TA is safe from demotion?
Jerry
RE: Can anyone identify this radio - by TA Forbes - 11-28-2012, 05:34 PM
RE: Can anyone identify this radio - by 7estatdef - 11-28-2012, 11:24 PM
RE: Can anyone identify this radio - by morzh - 11-29-2012, 12:21 AM
RE: Can anyone identify this radio - by TA Forbes - 11-29-2012, 02:36 AM
RE: Can anyone identify this radio - by jerryhawthorne - 11-29-2012, 08:04 PM
RE: Can anyone identify this radio - by TA Forbes - 11-29-2012, 08:19 PM
RE: Can anyone identify this radio - by Jayce - 12-01-2012, 12:53 PM
RE: Can anyone identify this radio - by TA Forbes - 12-01-2012, 08:57 PM
RE: Can anyone identify this radio - by TA Forbes - 12-01-2012, 09:01 PM
