38-15 finished
Ok one last post to brag.
My 38-15 is finished. The dial face has a place where the dial needle rubbed the gold foil off. Other then that and it works great and I installed an input for an MP3 player.
Pics:
[Image: http://i1129.photobucket.com/albums/m501...99A47A.jpg]
[Image: http://i1129.photobucket.com/albums/m501...D26A0C.jpg]
What it looked like when I got it in Kutztown in May:
[Image: http://i1129.photobucket.com/albums/m501...99f9c2.jpg]
-Keith
38-15 finished - by ipwizard - 11-30-2012, 11:37 PM
RE: 38-15 finished - by Dave D - 12-01-2012, 12:05 AM
RE: 38-15 finished - by chris25260880 - 12-01-2012, 02:14 AM
RE: 38-15 finished - by Paul Philco322 - 12-01-2012, 09:19 PM
RE: 38-15 finished - by Glenn Roberts - 12-01-2012, 09:41 PM
RE: 38-15 finished - by ipwizard - 12-02-2012, 08:15 PM
RE: 38-15 finished - by codefox1 - 12-02-2012, 09:45 PM
RE: 38-15 finished - by Tom Hamilton - 12-03-2012, 10:45 PM
RE: 38-15 finished - by TA Forbes - 12-03-2012, 11:06 PM
RE: 38-15 finished - by jerryhawthorne - 12-04-2012, 08:19 PM
RE: 38-15 finished - by fixinmyphilco - 12-04-2012, 08:56 PM
RE: 38-15 finished - by FStephenMasek - 12-05-2012, 01:29 AM
RE: 38-15 finished - by ipwizard - 12-05-2012, 01:39 PM
Philco 91 Tuning Condenser
