  • 1 Vote(s) - 3 Average
Newbie Cap Question
+1 what Codefox wrote.
Personally, I prefer replacing all wax/paper caps. They are usually leaky anyway, and are not trustworthy. Since some of them are connected to your B+ supply, failure could lead to damage up to and including your power transformer.
It is a good idea to restuff your bakelite blocks. There are several ways to do this described in this site.
Having done a couple of 91s, I recommend you also check your different transformers and filter choke for continuity.
Newbie Cap Question - by TheGorper - 12-01-2012, 10:54 AM
RE: Newbie Cap Question - by codefox1 - 12-01-2012, 11:58 AM
RE: Newbie Cap Question - by TheGorper - 12-01-2012, 12:21 PM
RE: Newbie Cap Question - by TA Forbes - 12-01-2012, 08:40 PM
RE: Newbie Cap Question - by TheGorper - 12-01-2012, 11:16 PM
RE: Newbie Cap Question - by TheGorper - 12-01-2012, 11:50 PM
RE: Newbie Cap Question - by codefox1 - 12-02-2012, 01:17 PM
RE: Newbie Cap Question - by TheGorper - 12-02-2012, 08:44 PM
RE: Newbie Cap Question - by morzh - 12-02-2012, 08:50 PM
RE: Newbie Cap Question - by TheGorper - 12-02-2012, 08:52 PM
RE: Newbie Cap Question - by 7estatdef - 12-02-2012, 10:36 PM
RE: Newbie Cap Question - by 7estatdef - 12-02-2012, 10:58 PM
RE: Newbie Cap Question - by TheGorper - 12-02-2012, 11:02 PM
RE: Newbie Cap Question - by 7estatdef - 12-02-2012, 11:30 PM
RE: Newbie Cap Question - by TheGorper - 12-03-2012, 10:22 AM
RE: Newbie Cap Question - by TA Forbes - 12-03-2012, 10:43 AM
RE: Newbie Cap Question - by TheGorper - 12-16-2012, 02:43 PM
RE: Newbie Cap Question - by TheFightingHellfish - 01-14-2013, 11:56 PM
RE: Newbie Cap Question - by TA Forbes - 01-15-2013, 11:29 PM
RE: Newbie Cap Question - by TheGorper - 01-31-2013, 12:12 AM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3445 online users. [Complete List]
» 1 Member(s) | 3444 Guest(s)
