37-630 (late version)mid chassis cap question
Hello Guys, I have the mid-chassis out (37-630 late version) on the bench for re-capping and replacing all the old point-to-point brittle cloth wiring. I am using my Riders vol 7 schematic and found a discrepancy. In the front compartment of the mid-chassis Riders schemat calls for a .1 uf, and the orig large philco cap is a .10uf @ 450. ( part # 20 on Riders parts-list on pg # 60 philco 37-630.
The orig philco condenser needing replaced is orig part # (30-4170 P), which the orig part is still in place,(large cardboard tubular) and definately marked: .10 uf/450., and the part # matches in Riders. Was wondering which cap to use in mfds, that is correct, and if I should make a note of this for "correction" in my orig Riders book? Thanks in advance for helping me get the correct part info that should be used. Randal
37-630 (late version)mid chassis cap question - by Texasrocker - 08-04-2007, 06:22 PM
[No subject] - by Texasrocker - 08-04-2007, 08:09 PM
[No subject] - by Texasrocker - 08-09-2007, 10:23 PM
[No subject] - by Ron Ramirez - 08-09-2007, 10:44 PM
[No subject] - by Texasrocker - 08-09-2007, 11:17 PM
[No subject] - by Ron Ramirez - 08-09-2007, 11:42 PM
[No subject] - by Texasrocker - 08-10-2007, 12:29 AM
There are currently 3276 online users. [Complete List]
» 4 Member(s) | 3272 Guest(s)
AvatarAvatarAvatarAvatar
