Not a philco but
I'm trying to figure out where this radio came from and looking through
old copies of Broadcasting Yearbook for the call letters I'm not
coming up with anything that makes much sense. Not clear in picture
The call letters I think seem to be WEAS (Savannah) ? 1947
WINN (Louisville) ? 1948
WGRC or WCRC ???
If you can tell me what they actually are I can go back into Yearbooks
starting in the 30's
Thanks
Not a philco but - by w4rtc - 11-29-2012, 04:55 PM
RE: Not a philco but - by morzh - 11-29-2012, 05:39 PM
RE: Not a philco but - by codefox1 - 11-29-2012, 05:44 PM
RE: Not a philco but - by Ron Ramirez - 11-29-2012, 06:31 PM
RE: Not a philco but - by TA Forbes - 11-29-2012, 07:52 PM
RE: Not a philco but - by morzh - 12-01-2012, 09:10 PM
RE: Not a philco but - by Paul Philco322 - 12-01-2012, 09:21 PM
RE: Not a philco but - by morzh - 12-01-2012, 09:43 PM
RE: Not a philco but - by TA Forbes - 12-02-2012, 01:37 PM
RE: Not a philco but - by Ron Ramirez - 12-02-2012, 05:33 PM
RE: Not a philco but - by chris25260880 - 12-03-2012, 12:33 AM
RE: Not a philco but - by TA Forbes - 12-03-2012, 10:49 AM
RE: Not a philco but - by w4rtc - 12-03-2012, 05:38 PM
RE: Not a philco but - by Arran - 12-05-2012, 01:43 AM
RE: Not a philco but - by chris25260880 - 12-05-2012, 02:20 AM
