38-15 finished
Nice job Keith, you are the "Wiz".
Jerry
38-15 finished - by ipwizard - 11-30-2012, 11:37 PM
RE: 38-15 finished - by Dave D - 12-01-2012, 12:05 AM
RE: 38-15 finished - by chris25260880 - 12-01-2012, 02:14 AM
RE: 38-15 finished - by Paul Philco322 - 12-01-2012, 09:19 PM
RE: 38-15 finished - by Glenn Roberts - 12-01-2012, 09:41 PM
RE: 38-15 finished - by ipwizard - 12-02-2012, 08:15 PM
RE: 38-15 finished - by codefox1 - 12-02-2012, 09:45 PM
RE: 38-15 finished - by Tom Hamilton - 12-03-2012, 10:45 PM
RE: 38-15 finished - by TA Forbes - 12-03-2012, 11:06 PM
RE: 38-15 finished - by jerryhawthorne - 12-04-2012, 08:19 PM
RE: 38-15 finished - by fixinmyphilco - 12-04-2012, 08:56 PM
RE: 38-15 finished - by FStephenMasek - 12-05-2012, 01:29 AM
RE: 38-15 finished - by ipwizard - 12-05-2012, 01:39 PM
Philco 91 Tuning Condenser
