38-15 finished
It looks good. There is a seller on Ebay who has many dial faces, and you may find one one of these days.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
38-15 finished - by ipwizard - 11-30-2012, 11:37 PM
RE: 38-15 finished - by Dave D - 12-01-2012, 12:05 AM
RE: 38-15 finished - by chris25260880 - 12-01-2012, 02:14 AM
RE: 38-15 finished - by Paul Philco322 - 12-01-2012, 09:19 PM
RE: 38-15 finished - by Glenn Roberts - 12-01-2012, 09:41 PM
RE: 38-15 finished - by ipwizard - 12-02-2012, 08:15 PM
RE: 38-15 finished - by codefox1 - 12-02-2012, 09:45 PM
RE: 38-15 finished - by Tom Hamilton - 12-03-2012, 10:45 PM
RE: 38-15 finished - by TA Forbes - 12-03-2012, 11:06 PM
RE: 38-15 finished - by jerryhawthorne - 12-04-2012, 08:19 PM
RE: 38-15 finished - by fixinmyphilco - 12-04-2012, 08:56 PM
RE: 38-15 finished - by FStephenMasek - 12-05-2012, 01:29 AM
RE: 38-15 finished - by ipwizard - 12-05-2012, 01:39 PM
Philco 91 Tuning Condenser
There are currently 5393 online users. [Complete List]
» 1 Member(s) | 5392 Guest(s)
