Not a philco but
They are probably alright sets, but would have the usual bugs of the other 1939-42 Zeniths like small power transformers, whacky power supply circuits (in some models), and rubber wire. One thing I don't like is the cheap cabinet touches with the faux inlay decals they liked to use, up until 1938 brand Z stayed away from faux grain, 1939 and later they seemed to use it extensively.
Not a philco but - by w4rtc - 11-29-2012, 04:55 PM
RE: Not a philco but - by morzh - 11-29-2012, 05:39 PM
RE: Not a philco but - by codefox1 - 11-29-2012, 05:44 PM
RE: Not a philco but - by Ron Ramirez - 11-29-2012, 06:31 PM
RE: Not a philco but - by TA Forbes - 11-29-2012, 07:52 PM
RE: Not a philco but - by morzh - 12-01-2012, 09:10 PM
RE: Not a philco but - by Paul Philco322 - 12-01-2012, 09:21 PM
RE: Not a philco but - by morzh - 12-01-2012, 09:43 PM
RE: Not a philco but - by TA Forbes - 12-02-2012, 01:37 PM
RE: Not a philco but - by Ron Ramirez - 12-02-2012, 05:33 PM
RE: Not a philco but - by chris25260880 - 12-03-2012, 12:33 AM
RE: Not a philco but - by TA Forbes - 12-03-2012, 10:49 AM
RE: Not a philco but - by w4rtc - 12-03-2012, 05:38 PM
RE: Not a philco but - by Arran - 12-05-2012, 01:43 AM
RE: Not a philco but - by chris25260880 - 12-05-2012, 02:20 AM
There are currently 9963 online users. [Complete List]
» 1 Member(s) | 9962 Guest(s)
