Philco 42-355
You're supposed to rub it on the wood, not your throat. ;)
Seriously, though, vodka has removed fresh water rings from my dining room table. The theory is that the alcohol in it is supposed to help the water evaporate, though I suspect it may well be a more a case of redistributing the finish after using the alcohol as a solvent. I'm waiting to hear from the pros on the Phorum on this little house-spouse trick.
Philco 42-355 - by idaho181 - 12-04-2012, 03:28 PM
RE: Philco 42-355 - by Ron Ramirez - 12-04-2012, 04:52 PM
RE: Philco 42-355 - by idaho181 - 12-04-2012, 04:57 PM
RE: Philco 42-355 - by Ron Ramirez - 12-04-2012, 05:00 PM
RE: Philco 42-355 - by idaho181 - 12-04-2012, 05:24 PM
RE: Philco 42-355 - by jerryhawthorne - 12-04-2012, 08:17 PM
RE: Philco 42-355 - by idaho181 - 12-04-2012, 08:33 PM
RE: Philco 42-355 - by jerryhawthorne - 12-04-2012, 10:12 PM
RE: Philco 42-355 - by idaho181 - 12-05-2012, 12:55 PM
RE: Philco 42-355 - by DeckApe - 12-05-2012, 02:14 PM
RE: Philco 42-355 - by idaho181 - 12-05-2012, 02:25 PM
RE: Philco 42-355 - by DeckApe - 12-05-2012, 05:10 PM
RE: Philco 42-355 - by idaho181 - 12-05-2012, 05:52 PM
RE: Philco 42-355 - by TA Forbes - 12-05-2012, 06:34 PM
RE: Philco 42-355 - by jerryhawthorne - 12-05-2012, 06:54 PM
RE: Philco 42-355 - by idaho181 - 12-06-2012, 03:08 PM
RE: Philco 42-355 - by jerryhawthorne - 12-06-2012, 03:22 PM
RE: Philco 42-355 - by idaho181 - 12-06-2012, 03:31 PM
RE: Philco 42-355 - by jerryhawthorne - 12-06-2012, 05:01 PM
RE: Philco 42-355 - by idaho181 - 12-06-2012, 05:11 PM
RE: Philco 42-355 - by Ron Ramirez - 12-06-2012, 05:13 PM
RE: Philco 42-355 - by jerryhawthorne - 12-06-2012, 05:31 PM
RE: Philco 42-355 - by idaho181 - 12-06-2012, 06:26 PM
RE: Philco 42-355 - by jerryhawthorne - 12-06-2012, 09:58 PM
RE: Philco 42-355 - by idaho181 - 12-07-2012, 12:33 AM
RE: Philco 42-355 - by jerryhawthorne - 12-07-2012, 02:09 AM
RE: Philco 42-355 - by idaho181 - 12-07-2012, 12:20 PM
RE: Philco 42-355 - by Ron Ramirez - 12-07-2012, 12:30 PM
RE: Philco 42-355 - by idaho181 - 12-07-2012, 12:32 PM
RE: Philco 42-355 - by Ron Ramirez - 12-07-2012, 12:49 PM
RE: Philco 42-355 - by idaho181 - 12-07-2012, 12:55 PM
RE: Philco 42-355 - by idaho181 - 12-07-2012, 02:12 PM
RE: Philco 42-355 - by Ron Ramirez - 12-07-2012, 02:29 PM
RE: Philco 42-355 - by jerryhawthorne - 12-07-2012, 02:47 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2572 online users. [Complete List]
» 2 Member(s) | 2570 Guest(s)
