Parts for Philco 42-365-- what is this called?
Hi,
Welcome to the Phorum!
And it is I, G. Gordon...er, um, I mean, Double R, known irreverently to some as Mister Philco.
I believe the rubber mounts you are looking for are probably the Philco Chassis Corner Mounts, and new reproductions may be found <a href="http://www.renovatedradios.com/parts.html">here</a> (scroll about halfway down the page).
The chassis would have been held in originally with sheet metal screws; the rubber mounts were there to reduce microphonics.
For knobs, look here:
http://www.antiqueradioknobs.com/partlistings.html
Larry Bordonaro offers THE BEST reproduction knobs and escutcheons, period.
Don't know why your dial would be backward? Perhaps something as simple as the dial cord being strung incorrectly?
Parts for Philco 42-365-- what is this called? - by Guest - 08-06-2007, 02:50 PM
[No subject] - by Ron Ramirez - 08-06-2007, 10:15 PM
[No subject] - by Guest - 08-07-2007, 06:06 AM
There are currently 8412 online users. [Complete List]
» 2 Member(s) | 8410 Guest(s)
