Model 50-1718
The Model number says it all. It was made for the 1950 model year, which means it was probably on the shelf last quarter 1949.
Model 50-1718 - by Guest - 08-07-2007, 09:24 AM
[No subject] - by Chuck Schwark - 08-07-2007, 11:35 AM
[No subject] - by Ron Ramirez - 09-15-2007, 11:48 AM
philco 50-1718 speaker ? - by Guest - 12-29-2007, 02:23 AM
[No subject] - by Chuck Schwark - 12-29-2007, 11:41 AM
Philco 91 Tuning Condenser
